Wheelies on stock engine?
RE: Wheelies on stock engine?
I think all just make him race me because he still claims to other people that he has awd and twin turbos so I'll just put him on the spot with his friends and see if I can gain some money while I'm at it. If not then I'll just git the satisfaction that everyone thinks my car beat a twin turbo beast the really can't hardly break the front wheels lose.
Really I don't even know if it is a eagle talon I know nothing about tuner cars/ricers.
Becarefull its not like a Ferrari 355 or something. That would be embarressing. This rich jackass "challeged" my friend who has a slightly modded roush stage 2 to race last year and he said he had a little import. Yeah well he got it handed to him by the Import. 355 Spyder with tubi exhaust and ecu work and all that. That car was fast. Stupid rich kids.
My ex had an Eagle Talon AWD turbo (a '91 IIRC)--it was pretty quick when new. However, I once made the mistake of turning the pop-up headlights on at 125 MPH and thought I was going to die, I swear the front-end cam up off the ground 'til I got down to 95 or so...[/align][/align]
ORIGINAL: White 96GT
I Really I don't even know if it is a eagle talon I know nothing about tuner cars/ricers.
you could probably do it with slicks but then youd need a 31 spline rearend and a heavy duty clutch. You would also need one of those drag suspension packages. That would likely get atleast one wheel off the ground an inch or two. Don't expect to be dragging your bumper all the way through first though
ORIGINAL: Morbid Intentions
302 stroker bored and cammed to the teeth with slicks and skinnies.... the only all motor newer stang I've seen pull it off.... every one else is a fox body or blown
99 GT $6500
Cold Air intake $159
75mm Upper & TB $289
Upper/Lower control arms $209 (UPR)
Lakewood 90/10 or 70/30's $198/pr
Strange 10 way rear shocks $140/pr
4.10's $200
Off road H or X $159
Cat Back $300
Stage II Cams $625
Springs for Cams $229
SCT Tune with chip or XCal2 $379
Weld Rims/Tires $800 - used
Oh and everyone just to let you know the talon thats AWD is called the talon TSI. You will definately need a built rearend and some slicks and skinnies thats at least a start. Like someone said above you probably want 31 spline axles.
EDIT: I'll let you know once i get some slicks and skinnies because i have 31 spline axles and 4.30 gears. But, my motor is definately not stock(well a stock block thats about it).
[align=left] [/align]
