throtle body help
throtle body help
i need some suggestions on what brand throtle body and plenum to get any responce would be helpful. and if i change the trotle body do i have to change the mas air flow sensor? thanks
RE: throtle body help
To be honest TB and plenum dont really add that much HP unless you go some kind of F/I. The only reason i got mine is it was really cheap $130 for trick flow TB and plenum. I would spend the money on something else.
First do like i also need to do and get the power that you have to the ground!!! Upper and lower control arms. And some drag radials. Also look into a NOS kit for the $450 that you would spend on 4-5hp on TB/P you could do a 75shot of juice and get 75hp its that simple and with a good tune safe also.
