Nitrous questions
Nitrous questions
I'm new to nitrous and am concerned about a few things... Will my car pass inspection with a nitrous system all hooked up? and also..even if i'm not going to use nitrous all the time in my car do i still want to have it tuned? what kind and how can i tune it? and with my car tuned for the nitrous system will it make the car run wierd when its not running nitrous? any advice will help me out.
RE: Nitrous questions
No it should not effect inspection. If you run a 75 shot (wet) you should be ok with out a tune but i would run a fuel safety switch and at least do a dyno run w/ A/F just to make sure your not leaning it out. No your car should not run weird with a different tune if you do tune it they will prob just put more fuel in it at WOT or above 4,000.
It doesn't matter if you won't use it all the time. You still need to have a tuner make sure everything A/F and timing wise is okay. If you run over a 75 shot you will need a custom tune. When my NX system is complete, the tuner I am taking it to is going to adjust the jetting to make sure that my A/F ratio doesn't lean out.
If you run a dry system you will absolutely need a dyno tune. Go to the Pipes, Boost & Juice area of this forum and look at the Nitrous Sticky at the top of the page to find out more.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
