Any PTV issues???!!
Any PTV issues???!!
If i want to get comp cams 278's, and put them in my 99 GT motor that is stock except for forged internals (all stock length and sizes) will there be any PTV issues or any other problems i should know about? also will there be any problems with 270's either. With both I WILL BE USING comp beehive valve springs. Anyone who has either ofthese, any info will be helpful thanks!!!
RE: Any PTV issues???!!
im hearing a lot of different things... with the 278's im pretty sure you will need the pistons flycut but with the 270's im hearing you dont, you you degree the cams correctly you'll be fine...so i heard, anyone else with info thanks for your input!
lincolnshibuya
12-08-2015 04:37 PM
