Spring install HOW TO?
Old 01-17-2007, 08:32 PM
wwmost
wwmost's Avatar
Default RE: Spring install HOW TO?
the 4cyl springs are more for the track. but the spring install is super easy once you do it once. the fronts are the hardest. just make sure your brake caliper doesnt get hung up or snagged when you lower the jack. hang it from somewhere and take off the ABS sensor bracket and sensor.
wwmost is offline
Old 01-17-2007, 09:46 PM
jmmorgan82
jmmorgan82's Avatar
you def do NOT need a spring compressor for the rear springs. you will need one for the front if you don't have any patience. My front springs just required a nice sized pry-bar and they slid right in.
jmmorgan82 is offline
Old 01-17-2007, 09:53 PM
wwmost
wwmost's Avatar
ORIGINAL: jmmorgan82
yea i didnt use a spring compressor at all. the fronts were a bitch though. i also used a pry bar and had to not put on my bottom isolator for them to slide in. if i kept it on it would go on smoothly. this is with steeda sports. not much of a drop but anough for me.
wwmost is offline
mtgldr
02-03-2024 09:00 PM
PullTab
10-30-2015 08:46 AM
Luke9222
09-04-2015 06:46 AM
09-01-2015 08:16 PM
Quick Reply: Spring install HOW TO?
