gears
RE: gears
Gears essentially multiply the power your car is making. The lower the gear you get (higher numerically), the faster you car is going to accelerate at any speed. Even with 4.10's you should be able to hit 150mph and do it much faster than if you were to have a taller gear. The only thing I can think of is if you were spinning more, but you said you guys went from a pretty fast roll, so I don't know what the deal is. Maybe he is a better driver?
RE: gears
ORIGINAL: SINISTER
RE: gears
Easy there cowboy. I had gears in my old Mustang, I know how they work. And I also know that you will not hit 150 in fourth gear, hell, I can't go much over 130 in fourth with the stock gears I have in this Mustang. However, you shouldn't need to go into fifth when racing your buddy, everyone knows that the race is over for us once we max out fourth gear. That being said, I don't understand what your problem is. If you have 4.10s, you should be ahead of him by the end of the 1/4 mile, and unless you cross the traps at around 108 or so, you shouldn't be worrying about it.
RE: gears
you dont understand what i was saying. we were racing from a high roll. prolly about 50 or 60. that means i barly have any of 3rd left and have to go into 4th right when the race starts. not much room for error there. so its def not a drivers race. i can beat him from a slower roll. maybe when we start in second.
RE: gears
Ok, I didn't realize you were starting from that high up. You still out pull him through all of fourth though, don't you? And yeah, just going into fourth is far from a driver's race. Again, my bad.
RE: gears
ORIGINAL: Dan04COBRA
How would 4.10's slow you down from a roll? I don't quite understand what is so difficult to grasp about the concept of gears for everybody here.
A shorter rear gear will make your car accellerate faster than a taller rear gear in ANY GIVEN SCENERIO. No need for further replies.
Going from 3.73 to 3.90's wouldn't be worth it unless you are doing the swap yourself. Compensate with a taller tire, LCA's & be a REAL GEAR HEAD and go with 4.30's and leave nothing on the table.
4.10's give you a bad start if you start at the same speed as a stock gears sweet spot, but you catch up pretty quick
RE: gears
ORIGINAL: SINISTER
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
