White smoke???
RE: White smoke???
Blue smoke is oil. A small amount of white smoke is alright, how much white smoke are we talking, is this on a cold or a hot day, has it increased, has your coolant been going down at faster than normal levels? These will help us out inhelping you.
RE: White smoke???
Its normal for a car to burn a small amount of oil during regular driving. If there is no blue tinge to the smoke, it is not due to excessive oil burning. Check your coolant level and see how it is. If you do not add coolant, I would say it should just be normal smoke. How hard are you getting on it when you see this cloud, normal acceleration?
RE: White smoke???
white smoke is water has it been doing it for a while? where do you get gas? try another place if you get it from the same place all the time.
blake smoke: gas
blue smoke: oil
white smoke: water or tires.
blake smoke: gas
blue smoke: oil
RE: White smoke???
no it runs the same no problems it will smoke when iam at sitting at the bank in line then i get done and drive away it leaves a cloud behind and it smells like oil..........if it were oil would it be my rings or my valve seals
RE: White smoke???
If you have any type of resonator muffler, your car will smoke for a long time. I have SLP LM II's which have little holes in the flow through part that are surrounded by a insulation type baffling. It gets wet from condensation and it takes forever to burn off.
