HELP!! STUCK IN THE MIDDLE OF SPRING SWAP!!
Well I got the passenger side spring off, and the rotor is litterally on the groud. WFT wont this other spring go in? ITs a foxbody 4cly spring. ITS THE SAME ****ING SIZE as stock.
What can I do? Its just impossible to force it in there as it sit. THANK YOU FOR YOUR HELP!
Do I need to cut this bitch?[/align]
RE: HELP!! STUCK IN THE MIDDLE OF SPRING SWAP!!
If the sway bar and the steering is all unbolted you should be able to fit lift springs in it. Your lower a arm should fall to the ground. Also you didnt need to take off your brakes but whatever floats your boat
DUde there is no way. I need to look at them! You may need to slice half a coil off. Can you get the stockers back in? You didnt use stupid spring compressors did you?
ORIGINAL: 01GTstang
just got done doing my fox body 4cly spring install all I can say is its gana take some kicking! lol maybe a spring compressor
Zach 731-414-7816
do you have isolators on? take them off, spray a **** load of wd40 on the spring purch and get a pry bar in there and get a budy to lift up the arm while you are using the pry bar to kinda compress the spring a little and prying it in at the same time. it is hard for you because you have the same size springs as stock and not shorter then stock. usually its real easy for people like ben whos went in real easy because his springs were 2 1/2 inches shorter then stock. my steeda sports werent that much shorter so it was pretty hard but i was out there all night and day tryin to get the front ones on. the back ones are the easy ones.
