RE: How slow are the 96-98 4.6 than the 99-04 4.6?
ORIGINAL: RipTide7
just butting in here, but yoteehunter, how easy was the livernois pi intake to install
The kit was very easy to install I did it in the parking lot at my apartments in almost dark in an attempt to work on my car with out getting in trouble(the apts. dont allow it). That kit very nice, it had good directions and every single part was there. The hardest part was driving out the old coolent pipe nipple behind the water pump, and loosening the bolt that holds the old coolent pipe bracket on the back side of the drivers side head. It took me about 3 hours but that was not working fast either, I could see someone doing the swap in a shop in about 1 hour with a good tool set and air power.
You should be able to get away with nitrous with the RTV method of mating up the pi intake. You really wont be inducing more pressure in the intake, at least not enough to cause a leak at the gaskets.
