Help me find my leak (PICS)
RE: Help me find my oil leak (PICS)
Like already stated clean everything off with brake cleaner. I'm gonna say your leaking from the steering gear lines. Jack the car up put it on Jack stands and after it is clean have a friend turn the wheel from one direction to the other while you are under watching the connection area's watch the area's that where really wet and dirty before you cleaned them. make sure all lines are tight it that's not it check what everyone already said.
ORIGINAL: BlackMustang02GT
im looking at a possible power steering leak?
I've got a buddy that has a Mustang performance shop. A few weeks ago we had my car on his lift checking the rear end and got to talking about the leak as we were finishing up. He says it is the power steering pump. He says there is a little rubber gasket/washer on the underside of the pump which is leaking, and that rubber piece can be replaced and fix the leak.
Anyone know where to get this rubber piece?
ORIGINAL: AmericanRicer87
are you sure its engine oil and not power steering fluid? fords psr's suck. start checkin other fluids, your engine isn't the only thing that uses oil...
ORIGINAL: BleedinBlue
Oil pressure switch...huh, theres a new idea. Thanks
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
