PI swap or 100 shot
PI swap or 100 shot
I'm sixteen and getting my liscence in a little less than 2 months and i'm trying to decide what i want to do to my car. I want to do the PI swap with some ported heads but getting money for this is an issue so i was thinking about the 100 shot of nitrous which is much cheaper. So what do you think? should i get the 100 shot or should i save for a while and then go with the PI swap. I'm all about the motor and PI swap but i need some convincing so that i will start saving. Also my car has 97k on it if that has anything to do with this decision.
RE: PI swap or 100 shot
Nitrous is cool but also it sucks when your bottle runs out[:@] a PI swap would give you less total power but that power would be there always.
Also, nawzz is technically illegal to use on the street so,, if your intent is to use your car on the track get nitrous, If you mostly drive street save up for the PI swap
Well if money is an issue, you could do what i ll be doing this spring. Just get a pi intake and some pi cams, or aftermarket stage 1 cams, the heads arent the majior problem. it should be good for anywhere between 40-50 hp.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
