am i the only one?
I got 03 Cobra wheels and noticed that when I am backing out and cut the wheel all the way to the right something is hitting. I assume that is because the GT was never intended to have a 9 inch wheel up front. Is this true or do I have a bigger problem?
RE: am i the only one?
Don't turn the wheel completely one way or the other.. Problem solved.
i knew that. Also I heard somewhere that if you drop $150 you can get the cobra A arms to allow for the turning.
I have the same "problem." Not a big deal since I almost never pull U-turns. When I do I just don't worry about it:D
ORIGINAL: gt96stang Don't turn the wheel completely one way or the other.. Problem solved. |
i have em too, never noticed that tho.[&:]
Is that a CRX Stang in your sig?
that happens to mine up front too, its because of the bigger rim. I got 9" wide in the front and if i back out and cut the wheel it rubs against the chin spoiler type thing. When i put the stock rims back on it doesnt do it anymore (only for the winter though). Just try not to turn it all the way.
ORIGINAL: 04CrimsonGT Is that a CRX Stang in your sig? It looks like a 05-06 with a fox style looking body kit on it. Looks good |
ORIGINAL: 04CrimsonGT Is that a CRX Stang in your sig? I hope you have at least heard of it......... [&:] |
