Black Smoke Want Run- Help!!
I recently have been having a problem with the stang, it will run a while and quit i have to keep at it till it starts again. It blowed abit of black smoke, its gotten worse now, it blows a lot of black smoke and finally throwed a CEL for MAF sensor, so i changed it and reset the ecu. Its still doing it but not as bad. Any ideas??? Maybe Temp sensor? This is a 2001 Gt[align=left] [/align]
RE: Black Smoke Want Run- Help!!
Could be either...a rich condition could be caused be several,several things...did the check engine light come back on?if so ,,is it the MAF again?Idle real ruff?did you do a once over for vaccum leaks?yes an ectsensor can cause this,,also a skewed 02 sensor reading very lean,,,iac motor suck open,an injector stuck wide open,...another bad maf,,possibilities are endless...Sorry.....without a scanner of some type,,someone who knows what they are looking at,, it might be difficult to find..
You may have a fouled O2 sensor. Get the codes pulled somewhere. When the O2 sensor fouls, it causes the car to run rich and idle rough.
And just because I am a grammar ****, it is "won't run," "blew a bit of black smoke," and "threw a CEL."
ORIGINAL: hawks05
lol the grammer got me as well. im not the best person to call someone out about it, but damn
