What size tire for this rim? (pic)
As you can see the stock 245/45s look very small on this rim. I'm not sure if it's the 8" or 9" but I'd like to go something wider, while at the same time not have it bulge in the middle and cause premature wear. Any opinions? I want to keep these rims by the way., I'd love to get a 10.5 for the rear but I can't afford new wheels at the moment., I just want a wider tires while at the same time fitting properly on the rim.
http://i47.photobucket.com/albums/f1...wk79/must5.jpg |
RE: What size tire for this rim? (pic)
305/40/18"[8D].
ORIGINAL: WLG101190 305/40/18"[8D]. |
I agree... 275/40
275/40 is the widest you should go. That's what I run on my stock 17's. Your's and mine are both 8" wide rims.
Like I said 275!;)
ORIGINAL: rlsracing I agree... 275/40 |
Are you sure 275 will not bulge? Since my wheel is 8" I hear it's too big check out this thread ( https://mustangforums.com/m_2570749/...tm.htm#2570928 ) ., I'm sure 275 will fit but I just hope it's not too wide of a tire for my rims. Oh and I don't want to lower the car because it's my DD and I like it a little higher, has more of the old muscle car look. If I was going rice I'd lower it. :P
ORIGINAL: 96GT226410 275/40 is the widest you should go. That's what I run on my stock 17's. Your's and mine are both 8" wide rims. |
ORIGINAL: 96GT226410 ORIGINAL: 96GT226410 275/40 is the widest you should go. That's what I run on my stock 17's. Your's and mine are both 8" wide rims. |
