>>How good is Royal Purple??<<
I have used synthetic for years but have never tried the super high end stuff like Royal Purple and Amsoil. Is Royal Purple worth the money or should I just stick with Mobil 1?? Also is 5w20 ok for a 2000 stang gt??
http://americanmuscle.com/royal-purp...motor-oil.html< is that a good price?
RE: >>How good is Royal Purple??<<
I tried the Motor Oil in my GT and didn't notice any difference. It felt exactly the same as it did before I put it in. I also tried the tranny fluid. The tranny fluid worked well. Shifting was a lot softer. It was easier to get in and out of gear.
Thanks for the replies guys, so do you all think that mobil 1 and rp are the same quality? if so I guess I will stick with whatever is cheapest. So what weight oil do you guys use in a 99+ gt??
I use 5w-30 Amsoil, which is buy far the most economical of the oils you mentioned. They have the longest warrantied drain interval, which saves a lot of money and time.
Quality wise, Amsoil and Royal Purple are quite a bit better than Mobil 1. I'm not saying Mobil 1 is bad, it is just isn't in the same league as Amsoil and Royal Purple.
