What mods next for my 98 GT?
I just got the PI cams and intake, skipping the heads. I am assuming 4:10 gears should be next? Are a 70-75mm TB and CAI even worth the money? How much rwhp gains are the TB and CAI good for? Thanks
RE: What mods next for my 98 GT?
ORIGINAL: Mr. E
ORIGINAL: lizzyfan
Not as much a gain as the heads
ORIGINAL: Mr. E
Without PI heads, you will get even LESS of gains with a TB and CAI over PI heads, which with those, its barely anything anyway. You can get a CAI for like 100-200 bucks, then a good TB/plenum combo for like 400-500. And you are already at the price of those heads (you say ~$750), with less gains. Save up.
ORIGINAL: handyandy
ORIGINAL: handyandy
Man, I hate to break it to you but youwill see hardly any gains from your bolt on mods until you ditch those non-pi heads. The heads are the restriction on your motor. You can put all the bolt on's you want but thats not what is holding the engine back. With full bolt on's with non pi heads you will be lucky to see a 15 rwhp increase. With the cams and intake you put on, you might see 20-25 rwhp increase.
Whoever told you that you would only get 8-10 hp with the PI heads were full of crap. With a full pi swap you will see about 40 hp increase on a completely stock motor. Most of that coming from the better flowing heads.HP will be just above what a stock 99-04 makes because your compression will be a little higher.
Hmm, seems people have differing views on this. I was going by what I read about PI swaps and what I saw on a few other boards. People saying you can do just as well with PI cams and intake with the stock heads. Wish I knew for sure, seeing some dyno proof on it. I certainly dont wanna spend $750 on heads to get a lousy 8-10 rwhp.
ORIGINAL: Mr. E
