which clutch is best?
i have a pretty stock Cobra, and i am planning on upgrading it over time.. im looking at clutches, and i was wondering what the best clutch and pressure plate is on the market.. im looking for a Clutch and Pressure plate that has an easy pedal feel and that isnta real rough ride when i engage and disengage it..
what else will i need/do when i replace the clutch and pressure plate?
RE: which clutch is best?
ORIGINAL: rbstang
Spec or Fidanza are the only 2 clutches i would use on MY mustang.
i currently have a spec stage 1 with aluminum fly and i love it. i use to run fidanza on my old gt.
any recommendations on aftermarket flywheels? or can i just resurface mine? i have 104K miles on it.. and not sure what the guy did with the Flywheel when hereplaced the clutch
i have spec aluminum flywheel but i spent a pretty penny on it... 104k... might be able to resurface the one you (im going on the assumption its been replaced) other wise you can A) buy an aftermarket one B) buy stock oem one C) resurface the one you have. With the aluminum fly all i have really noticed is that the engine seems to rev up faster.
ORIGINAL: rbstang
I will have to say stay clear ofcenterforce. mine has given me nothing but problems so far. First off therethrow out bearing sucks had to replace it after 4 months. And my buddy has the dual friction and his pedal is pretty stiff and it not the smothest at engaging.
