IRS drivetrain loss?
I was reading in the S/S section about some stupid LS1 argument. They said that a LS1 vette will dyno lower than a LS1 Fbody b/c ofIRS.
Does IRS really cause lower rwhp? If so, how much?
RE: IRS drivetrain loss?
There are more moving joints on an IRS. For every joint you have you have friction loss. Thats why a 4wd truck dynos lower than a 2wd truck even if they are the exact same.
I have to disagree with you guys on the more moving parts theory. they both have a diff that either spins 2 axle shafts or they spin 2 half shafts. I would lean toward Rotating Mass being the culprit of less HP from the same engine. I guess the only was to know is if someone dynoed with a IRS and than pulled it dynoed with a solid axle and compare.
ORIGINAL: BraMas
09-17-2015 07:32 PM
09-16-2015 07:53 PM
09-01-2015 08:16 PM
