Front End Question!
RE: Front End Question!
Center steering wheel,,,,,adjust tie rod sleeve and pull it in...you can set it with a tape measure to get it close...stretch the tap from the front ,,wheel to wheel,,,and then from the back wheel to wheel(same exact spot on tires...and the front make 1/16 less than the rear....that will get you to the shop for that alignment...
On the pass side the whole tire looks like it is out a little less than 1/4 inch because if i look down the back on each side on the pass side i can see the tire sticking out and on the driver side i can barely see the tire at all it is more in the fender well
ORIGINAL: Brandons98GT
mikecaputo
08-22-2015 10:58 AM
inyadreems
08-21-2015 09:10 AM
