tranny fluid
RE: tranny fluid
Well. you either remove the shifter bezzel, boot, handle, and shifter, and fudge up the gasket and then have to put it all back together again. Or you can use a small pump to pump it in the fill hole and stop when it spills out the same hole. I filled it throught the fill hole when I was changing the clutch, and it was pretty easy.
Matt
Matt
RE: tranny fluid
thanks guys.. just bought 4 quarts of RP synchromax. I also am doing it on my buddies lift, so as long as the fill plug isnt too hard to get to, I'm not going to bother to pull the shifter.
RE: tranny fluid
I also did mine on a lift, and i really didnt realize that...thats a good point. If you dont have access to a lift, it might be easier to just pull the shifter (and put in a short throw while youre at it). But yeah, with a lift, its a piece of cake. The fill plug just uses a 1/4 drive rachet (just the actuall ratchet, not socket on it) and is simple to get at it.
Matt
Matt
treesloth
09-28-2015 07:03 AM
09-25-2015 06:42 PM
