FRPP B or C springs
FRPP B or C springs
I was wondering if anyone has the B springs on this site. Also, do you thinkI will have any rubbing issues if I lower the car about 1.25"? I have 315/35/18's on the back Thanks.
Could you post some pics of your rides with either the B or C
RE: FRPP B or C springs
Most forums I visit state you have to wait at least a day to bump your own thread, not an hour. MF should make that a rule.
As for your question, search! There's quite a few pics of Mustangs lowered on C springs. The C springs basically have the same drop as the Pro-Kit. For the B springs, just imagine the car a little higher. I don't believe you'll have rubbing issues on your car, even with the 315/18. I have 315/17s, and there is a good bit of space left. 335s maybe?
ORIGINAL: MBentz
You will be just fine with the C springs no doubt. They are a quality spring with a mild drop for a very good price.
ORIGINAL: MBentz
the ford racing springs have a different drop in front vs. in rear, so a prokit pic will not do it justice. the ford racing springs will drop more in the front than the back and will give you a little bit of a rake. enough to give a different look, but not enough to look odd. the raked stance goes well with the new edge lines, imo. C and B springs will drop the same height, they just have a different spring rate.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
