steeda timing adjuster install
man does this thing work!!! quick and easy to bolt on, then iadvanced the timing to 16A and bam, i got myself a pretty hefty gain. this is a must for guys who dont have an sct or a predator.
RE: steeda timing adjuster install
it bolts right up to the crank pulley. then you relocate the sensor to the pulley. takes about an hour or so to do. it stays on and you are able to advance and retard the timing. i dont know much about tuners, but form what ive heard you can advance the timing. timing adjuster goes for about $150.
ORIGINAL: jusnkris
ORIGINAL: submit
I bought a used Predator tuner for $150. If you are patient you can find a deal on ebay. I advanced my timing via a performace tune in less then 5 mins
ORIGINAL: jusnkrisit bolts right up to the crank pulley. then you relocate the sensor to the pulley. takes about an hour or so to do. it stays on and you are able to advance and retard the timing. i dont know much about tuners, but form what ive heard you can advance the timing. timing adjuster goes for about $150.
ORIGINAL: sweet99
The performance tune that comes with the Predator adds very little timing. If you have the tune that adds 10% timing in 2 rpm ranges it is adding 1* at 4K and 1.6* at 5K. I had to use the adjuster with the Predator tune because the predator tune was so lame. I added 6* on top of the Predators 10% increases and no knock with 93 octane. Mark
ORIGINAL: submit
I bought a used Predator tuner for $150.� If you are patient you can find a deal on ebay.� I advanced my timing via a performace tune in less then 5 mins
if i get a timing adjuster, does that mean i can get a 125 shot of nitrous instead of a 75 shot. cuz with the 75 i dont need a tune to retard the timing. but with a 125 i would need to. is there anything i would need to take it to a tuner for or could i just retard it myself with that and be ok?
ORIGINAL: therapistif i get a timing adjuster, does that mean i can get a 125 shot of nitrous instead of a 75 shot. cuz with the 75 i dont need a tune to retard the timing. but with a 125 i would need to. is there anything i would need to take it to a tuner for or could i just retard it myself with that and be ok?
ORIGINAL: submit
2001+ have more compression (9.4:1) so they can't take as much timing. I added 2* to the perf tune for now. I'll try 3 next time I'm messing with it...
ORIGINAL: sweet99
ORIGINAL: submit
