What exactly did you buy? Comp cams are good, but certain ones require upgraded valve springs, gears, fly cut pistonsand a tune. Any idea which ones you got?
Did you buy your parts used? Comp makes a couple different cams for our application. If they are aftermarket PI cams I do not beileve you can use them with your NPI engine, as you will have contact between the pistons and the valves.
