parking brake light
RE: parking brake light
Brake fluid is low in master cylinder because the brake pads are worn causing more fluid to be required in lines to push pads against rotor unless you have a leaking wheel cylinder or master cylinder. If you just add fluid and the pads are worn ,when you replace the pads ,the master cylinder will be overfilled.
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
09-08-2015 11:50 AM
