Last edit by: IB Advertising
Browse all: Powertrain Guides
- Ford Mustang Gt 1996 to 2004: How to Replace Water Pump
Step by step instructions for do-it-yourself repairs
how to remove water pump?
how do i remove the water pump on my car, i have the pulley off and the 4 bolts holding the pump off. the pump will not slide out.. is there a special trick in doing this?
RE: how to remove water pump?
worked perfectly.. thanks man.. waterpump is now on the new motor
one more question though.. does that rubber gasket need to be replaced?
Well,,should prob replace it,...You could add some blue RTV around it,,and it should seal up....or just put a new o-ring on it...Being a new motor,I might even go as far as just replacing the pump....When I did my S/C ...my pump looked original,,but wasnt leaking,,and just decided to pitch it in favor of a new one...was about 40 bucks...my cost for a new one not a re-man...Laters...
jaiidutch
09-14-2015 10:29 AM
