AirBag Light and Power Seat
Hey guys,
I noticed the other day that my airbag light is on, but sometimes it flickers and other times it is off but for the majority of the ride it is on. Also, my driver side power seat makes a little moan but the chair doesn't move either forward or backwards. I think that the airbag light is a sensor or fuse and the chair is just the motor, but I wanted to get your opinions. Thanks.
RE: AirBag Light and Power Seat
The air bag light sounds like something is loose, a connection of some sort is loose and causeing it to flicker on and off because it is functional and then not functional! It couldnt be a fuse, a fuse is either good or bad, no inbetween! As for the chair if it makes a noise then probably the motor is fine... look for something in the track, something might have gotten down there and made it stick... something along those lines would be my guess!
airbag light...there are 2 cesors attached to your radiator support and one of those may be bad. Also there is an airbag module behind where your shifter and radio is and it is a blue box. That may be bad. Just some suggestions.
mungodrums
10-07-2015 04:01 AM
zanemoseley
09-06-2015 12:58 PM
