Budget street suspension
Alrighty, like the title of this thread states, what would be a good budget suspension system? I have been looking into the mm coil over kit but i have been feeling more and more like that is overkill and that i can spend the money in other areas.....
anyways what kind of
Springs:
Shocks/Struts:
CC plates:
LCA:
Panhard Bars:
and is a front sway bar necessary for a dd car?
Springs:
Shocks/Struts:
CC plates:
LCA:
Panhard Bars:
RE: Budget street suspension
right off bat i can say that the stock tokico on my car are pretty nice so
http://www.gefracing.com/Merchant2/m...y_Code=BULLITT
LCA - maximum motorsports
http://cgi.ebay.com/ebaymotors/Maxim...spagenameZWDVW
you wont really need panhard bar on street suspension YET id say personally get used to top 2 mods and add subframe connectors before panhard
http://cgi.ebay.com/ebaymotors/STEED...80391649QQrdZ1
or maximum motorsports
If your looking for a true budget setup I would get the first link he posted (the bullit stuff) and these:
http://blueovalindustries.bluekeyinc...ts.php?pid=614
With this:
http://blueovalindustries.bluekeyinc...ts.php?pid=626
That would basically upgrade everything on the car, plus put subframes on it for stiffening. I am running these subframes and the control arms will go on soon so I can give you the results of those, but several others have ran em and love em.
With this:
hrmms I do a bit of twisties when I'm with the car club here, and I'm looking to spend about 1-2k for suspension just wondering for a mostly street app if the MM coil over is overkill? any alternatives to the bullit kit? looking for a in between, something better handling than the bullits but nothing over the top like auto x'ers
ORIGINAL: Aereon
The control arms are still good for you unless you want to spend alot more on them and get adjustable ones.. IMO a waste of money.
You will want to go with an adjustable setup on the shocks/struts. Here is what I just bought:
http://modularpowerhouse.com/index.p...baeb53894db133
The springs are pretty much up to you.. all that really makes them different is the drop and the spring rate. For a road race I would stay away from anything like a "drag launch" spring and just get a general lowering kit.
If your into road racing I would look into the bullitt brake upgrade kit as well. Brakes are one of the most important parts of a road race car, but unless you want to get serious (1000+)the bullitts are the cheapest/best route to go.
The coilover setup is a big improvement but expensive as well. I don't have personal experence with it so someone else will have to answer if it will fit your needs.
Scott...is it really easy to adjust the settings on the Strange adjustables? thats what i was looking at for my car and wanted to get a users first hand review. also when you get them do they come with recommended settings for best drag/comfort/autocross/etc?
kk thanks, just lookin for alternatives since I do not have all the money to purchase the mm coil over kit yet I was seeing what is available to piece together..I already have the mach1 brakes up front and wanna do suspension within the next month
if you want a good coilover kit you just need to buy compatible shocks/struts, do upr fronts 219.99 and rears Modular mustang racing299.99. Then your looking at another 200-300+ for shocks struts, c/c plates etc. What is your budget? I did all mine for around 1k
If you have your heart set on spending a butt load on suspension, then go with the Bilstein setup. From what I hear, they are about the best suspension parts you can buy for a mustang. And, they have that nice little lifetime warrenty. Here's a link: http://www.americanmuscle.com/bilste...age-94-04.html
But, if you want a good suspension setup, i would go with the bullit stuff. It's inexpensive and they make your mustang handle quite well. My buddy has those shocks and struts on his Mach 1 and it handles like a dream! I actually am planning to put on this set: http://www.gefracing.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=G&Prod uct_Code=M5400A&Category_Code=BULLITT tomorrow. I would get that set and then get the upper and lower control arms, bushings and sub frames with the rest of your money. Just my opinion, though
Aereon, for a budget street car based on handling within $1500 trust me when i say the bullitt suspension, full length subframes and MAYBE lower control arms.... honestly though id suggest to you (if i was in your case) get the suspension, do the subframes and tires (noticed your sig, dont know how much power you put out or sizes you have on but ive found it better for handling to have same size all around and light weight tires...)and they do make all the difference in handling (i can tell you from personal experience) and of course your skill, only do 1-2 mods at a time, drive it around and get used to it for a few weeks until you know the limits then slowly add to it;I say this with your safety/goals in mind.
cheers[8D]
cheers[8D]
