Clutches in LSD
Clutches in LSD
Took my stang in because it had a serious rubbing when the steering wheel was at full lock and accelerating a little bit. I was told it could be the clutches in the LSD but then they said it was just the e-brake cable that was rubbing. They fixed the cable but it still rubs, could it be the clutches in the LSD?
RE: Clutches in LSD
ORIGINAL: GreyStang
Yea is the rubbing sound coming from the front or rear wheels? Why would rear wheels rub while corniering??
RE: Clutches in LSD
If the rubbing is coming from the rear while cornering and accelerating, then maybe the rear suspension bushings are shot/worn & allowing the rear axle to move left/right(?)
If it's been making this noise for a while now, take each tire off the car & inspect them. You should be able to spot the area that's rubbing on the tire itself. 1st thing you gotta do is figure out which tire is rubbing!
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
