Got stuck in reverse gear!
#21
RE: Got stuck in reverse gear!
No way will that work...
The synchros for reverse will ONLY match up if the car is at idle. If I'm runnin cold, it grinds like hell getting in. ^^^^ Do not try that...
You wanna do 180's? Go to an empty space...bring the car to like 30 mph in 1st, pop it in neutral and turn the wheel all the way around. See if you can keep the car from spinning around again. I doubt it will work but that's my best guess of how to do it without f ing up your driveline.
#22
Stuck in reverse
So my 03 mustang gt just got stuck in reverse wouldn’t come loose while turned on but would shift normally off, called a bunch of mechanics and shops no one could tell me what it was I was about to walk away, throw in the towel. I read something about setting the clutch so Then I tried to pull up on the clutch petal until it clicked, all of a sudden it was working fine, idk what happened or if something got knocked loose but it worked for me so I figured I’d share this as well as see if anyone else has had this problem and what would cause the petal to come undone
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
