Holy mother of exhst leaks
RE: Holy mother of exhst leaks
I tell ya, I am tempted!
But since there's snow everywhere, I have the time to do a little more trouble shooting before Spring. Plus its FREE, well sort of, not including random trips to Autozone to find various fixes.
I went to Pepboys and looked through their assortment of high temp mufflre/exhaust reaparing gel/goop crap. They have the tape too or whatever the hell it does... eitehr way, I don't want this crap to become a permanant part of my midpipe.
i got my x pipe put on at minake maybe you should try there, no leaks and took them less then an hour good mechanics there
Summit or JEGS should sell "dead soft" gaskets for that location. Yep, JEGS has them for $14.99 a pair. They come in 2.5", 3" And, 3.5" tHEY ARE MADE FROM SOFT ALUMINUM AND ARE GAURANTEED NOT TO BLOW OUT. THEY ALSO HAVE MR. GASKETS VERSION, Copper seal for a buck more. These should take up any reasonable gaps but not sometyhing like 1/4"! Good Luck and let us know how they work if you get them. mark
i would try using the air tools to do it... i know i torque down all my flanges with air tools and they are on very good... although, i took off the header gasket yesterday and it has a hole about 1 inch wide blown through it in cylinder number 8... i thought percys gaskets weremade stronger?
Percy's standard header gaskets for $15. a pair are not nearly as good as their dead soft aluminum gaskets that are $34.95 even though they advertise them being able to withstand 2000*. I prefer the "dead soft" gaskets myself. mark
I went to Pep Boys too, for the two condensation leaks I also have at the rear two mufflers. I will slip this collar/band over the joint, then probably doulbe u-bolt clamp it down (make shift band clamp they don't have). Maybe also coat the edges with the Hi-Temp RTV I have before slipping the band over it. Then hopefully no more leaks there.
As for the header leak(s). I'm still not sure where it's comming from. I thought it was the Driver side, but I can't feel or see it after trying soapy water and blowing smoke in the area. I will try a Seafoam suggestion, as soon as I find out what that is...
