another turbo post
Old 02-07-2007, 10:39 PM
Fuel
Fuel's Avatar
Default another turbo post
just feeling out what the plansmay be for my car
i am set on building a non pi head engine build up and was wondering what kind of power i could see with a forged motor with pi intake and cams and a single turbo
what do u think and again i want to keep the nonpi heads just to be different and see what they will do
Fuel is offline
Old 02-08-2007, 12:01 AM
Fuel
Fuel's Avatar
Default RE: another turbo post
anybody
Fuel is offline
Old 02-08-2007, 12:09 AM
JJ03MustangGT
JJ03MustangGT's Avatar
the only problem with that is the heads. if you upgraded to PI heads youd make so much more power. why short yourself. id say rough estimate with a stage 1 cam, NPI heads, 56mm turbo, full exhaust, forged bottom end, maybe 450-500rwhp at 10-12 psi.
JJ03MustangGT is offline
Old 02-08-2007, 12:14 AM
Fuel
Fuel's Avatar
i was going to go with a 60mm turbo and i want to keep the nonpi heads just cause everyone says that i should change them, so i want to be a guinea pig to see what they can do
Fuel is offline
Old 02-08-2007, 12:17 AM
JJ03MustangGT
i can tell you that your goin to be very disapointed in them. not that PI heads are much better but they are an improvement. your best bet will be to pick up a set of worked PI heads. a good blower cam and check into the svo intake. id call mph about havin them custom grind you a blower cam. youd make so much power that way. but do what you gotta do man.
Old 02-08-2007, 12:18 AM
ant02gt
ant02gt's Avatar
im not sure what you will be putting down...alot of different things dettermine that. But why would you not go with pi heads. Does anyone know what kind of compression a pi swap would make
ant02gt is offline
Old 02-08-2007, 12:20 AM
lizzyfan
Underboss
lizzyfan's Avatar
ORIGINAL: ant02gt
10.5:1
lizzyfan is offline
Fuel
Fuel's Avatar
the heads would up the cr to 10.5:1
Fuel is offline
Old 02-08-2007, 12:22 AM
ant02gt
ant02gt's Avatar
okay thanks...i was just wondering
ant02gt is offline
Old 02-08-2007, 12:24 AM
JJ03MustangGT
wait i thought the PI 4.6 made 10:5:1 and the NPI made 8:5:1
Quick Reply: another turbo post
