funky idle - stalls
RE: funky idle - stalls
ORIGINAL: MikeHawke
Doh! you're right. i just wanted your opinions before i went to the dealer. codes said bad signal from mass airflow (or something like that)........wire was loose from the accident but didn't show up until i drove it for a bit. Dealer fixed it under warranty = cool.
Good call JD. you woulda had me looking in the right place buddy, thanks.
Get the codes pulled first, that will give you an idea where to look
This sounds kinda like the same problem I had when my mass airflow sensor was wet. Do you have a CE light on?
Not a problem.
Well Im sure there is some way to bypass it so the CE light goes off. I would look into it because thats the last thing you want is to NOT know when something seriously is going on with your shiz.
Mine is doing the same thing. I triedeplacing the TPS, that didnt work($28)and the idle air control valve, that didnt work either. But I would try those first. I need to get a code next.
bradleyb
11-27-2015 07:50 PM
