Loss of Power from Headers?
My brother has a '00 GT with a SCT tuner, JLT RAI, MAC cat-back, MAC o/r h-pipe, and we just installed some BBK shorty headers. With the headers on now, the car is sluggish down low, like it lost torque from losing back-pressure.
Once he gets going around 50 mph, the power really comes back and it pulls hard. The exhaust also gets deeper and sounds more powerful. With the full exhaustnow, does he not have enough back-pressure? I figured itwould be fine. Has anyone else put a full exhaust on a stock GT and got the same results? What do you think will fix this problem?
Next, to try and fix this, my brother isthinking aboutgetting an Accufab75mm TB/plenum to see if the added intake will bring back some back-pressure. What do yall think?
RE: Loss of Power from Headers?
well I dont think installing shorties would give you a significant gain in power, but it certainly shouldnt HURT your total hp/tq numbers. Maybe it feels sluggish down low, like many other exhaust components, due due it efficiency at higher RPM levels
shorties offer a different power band than what he's used to, they add hp in the top end at the sacrifice of low end torque...people will say the opposite about long tubes sometimes, because they make low end torque...but he's probably making more than he was before all around atleast...he should try re-tuning with the SCT...but im not one to ask about all that
Make sure there are no leaks. Modifications like such generally add HP/TQ all throughout the powerband, however some make a significant difference higher in RPM's & give the illusion that the car is actually slower than before.
There is no aftermarket header offered for 96-04 GT's that will cause any issues with too little back pressure. If you understood how backpressure worked you wouldn't be asking this.
ORIGINAL: Dan04COBRA
Huh? You said the lack of back-pressure could be the cause? It's not.
Make sure there are no leaks, otherwise it's all in your heads! You suffered no TQ loss. TQ was increased down low & up high, however the increase in TQ higher in your powerband will give the illusion that the car is slower down low than before.
