fuel pump 199.00??
RE: fuel pump will this work?
yes it's used. it has about 4k on it.
it's a 255lph pump not an autozone pump
and it will handle more than 400 ponies as well.
i would only recommend it if you plan boost. no point to dropping it in unless you need that much performance.
it's a simple install. just drop your gas tank
turn the metal clip
pull out old fuel pump and disconnect switch
than click, drop it in and close the metal clip.
turn the metal clip
mrappe
09-26-2015 10:16 AM
