4.6 stang stroked to 5.1
#41
RE: 4.6 stang stroked to 5.1
Your car is going to blow! If you shoot nitrous before the maf or after the maf it will make no difference. The maf meters the amount of air that is coming in not the amount of oxygen. You better do alot more research and learn about cars, how they work, and what you are having done to yours. Nitrous is one part nitrogen and 2 parts oxygen. When it is compressed it releases the oxygen which makes a hotter explosion. More heat more power.
If there is not enough fuel in the compustion chamber when the spark lights you lean out and bend rods, crack pistons, crack ring lands, and even crack heads. Wet shot is safer then dry. a dry shot is fine up to 50 shot but no more.
Don't go off when you are the one that has no idea what you are talking about. Listen to the people on this site who know more then you and the import shop you brought your car to.
10-09-2015 03:27 PM
