Suspension
RE: Suspension
Well, a start would be Upper/Lower control arms, sub-frame connectors. Then if you wanted to go further than that you could get shocks/struts and springs. Everyone on here will tell you its not too hard to install this stuff...but without a lift its a real PITA. You should be able to do the Lower control arms and sub-frames. I had to drop my exhaust to put in the uppers. Good luck man
RE: Suspension
ORIGINAL: yellowgtstang18
so will upper and lower control arms and subframe connectors make it ride better or just better traction or what..??
Matt's 95 Stang
10-05-2015 07:16 AM
