LCA's installed.
LCA's installed.
But, has anyone else done this before?
I had to reverse the nut brackets on my sway bar to make it fit... so the sway bar itself is on the inside of one LCA, and the outside of another.. did i miss something here?
Also, the "e-brake line / ABS sensor" bracket will not reattach to the sway bar, should i remove them (as I am changing my rear calipers here soon anyway) or find someway to juryrig them onto the LCA. Thanks
On the plus side, my stock bushings were more than shot, and now that annoying groaning noise is GONE!!!
(btw they are GMS LCAs, UCA's go in on tuesday!!)
RE: LCA's installed.
ORIGINAL: dlazrael
i just installed hpm lower control arms. they said in the directions to take the clips off of the sway bar and turn them around all 4. and they told me to cut the braket off for the ebrake abs thingy.
