mach 460 ? for a buddy
Old 02-11-2007, 11:28 PM
98redgt4.6
98redgt4.6's Avatar
Default mach 460 ? for a buddy
he bought a 98 gt black with a mach 460 system he wants to know what it consist of
98redgt4.6 is offline
Old 02-11-2007, 11:38 PM
mvr
mvr's Avatar
Default RE: mach 460 ? for a buddy
send him these links
http://www.flemworld.com/Mach460/Mach.html
http://www.evisteon.com/prod_serv/mo...60/index.shtml
mvr is offline
Old 02-11-2007, 11:43 PM
98redgt4.6
98redgt4.6's Avatar
so where there any subs with the 460
Old 02-12-2007, 12:07 AM
lsustang04
lsustang04's Avatar
No, just subs with the 1000.
lsustang04 is offline
Old 02-12-2007, 03:08 AM
98redgt4.6
98redgt4.6's Avatar
would a mach 460 amp be able to hold two 10 memphis power refrence
Old 02-12-2007, 03:09 AM
2000GT4.6
2000GT4.6's Avatar
Everything I have heard says you cannot use an aftermarket speaker on the amps that come with the 460. It uses a funky resistance speaker setup.
In any case, you should not try to run subs on the stock amps.. they are built for full range speakers (not subs) regardless of the ohm value of the speaker.
2000GT4.6 is offline
Old 02-12-2007, 03:13 AM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
You can run another amplifier to power your own subs through the Mach 460 though. It won't sound very good IMO, but it can be done quite easy.
Dan04COBRA is offline
Old 02-12-2007, 03:16 AM
mvr
mvr's Avatar
ORIGINAL: Dan04COBRA
thats what i did, i had a amp/sub/wireing kit left over from my last car so instead of it sitting and collecting dust me and a buddy wired it up. sounds good inside the car, and its enough bass for me.
mvr is offline
Old 02-12-2007, 03:23 AM
98redgt4.6
98redgt4.6's Avatar
so it would sound pretty ****ty if i took the stock amps off and just ran them without because i have a 2600 watt sound storm and two twelves i was just gonna down grade if it would so ill stick with the twelves
Old 02-12-2007, 06:38 AM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
The stock stuff sounds crappy, regardless of the stock amps.
1BAD3V
Tennessee Regional Chapter
10-06-2016 12:12 PM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
69Volunteer
09-30-2015 10:39 AM
Sixer4Life
09-29-2015 07:03 PM
Quick Reply: mach 460 ? for a buddy
