How to fix wind noise on my '99???
Car: '99 V6 Automatic
Problem: Excessive wind noise that seems to be coming from the rear, passenger-side area (like maybe from the rear window or rear-side window). The faster I go, the louder the wind noise.
I have noticed that the black exterior window seal can be pulled up a little bit by hand...should it be glued down? Other than that, I haven't noticed any seals missing or suspicious signs. The car has never been in an accident and never had any of the windows replaced.
Thank you for your help.
RE: How to fix wind noise on my '99???
i had the same problem with my front window molding, anywhere where you can pull it up, pull it up enough to goop some RTV in there and press back down and hold untill it stays, then allow to dry, that should fix you up
bradleyb
11-27-2015 07:50 PM
