Exhuast water/Smoke
Exhuast water/Smoke
I recently had my 2000 GT in a body shop and i had to get a ride to the shop to pick it up. On the way home the girl that drove me to the shop was behind me and she called me as we were driving and said that there was some smoke and water coming out of the exhasut. I got the car home and let it idle in the driveway for about 5-1o minutes. When i came out to look at it i noticed a light smoke coming from the exhasut. Im not sure if its smoke or water vapor. Also, there was a small puddle about 6-8 inches in diamter under both sides of the exhaust exit. Is this a problem. I nenevr noticed it before. Anyone have any clues as to what could be causing this.?
RE: Exhuast water/Smoke
I get that on my drivers side pipe. I think I blew a head gasket on that side only. I turn off the car, and light smoke or steam comes from it too. It also has that puddle at idle, and even a little bit of water from the other side as well. I'm not worrying about it too much. No water under the cap though.
same thing with my car my car has been sitting in the garage since june 1 and when i start it it smokes a little and when i rev it up it leaves a long line of water on my patio its fine though after i let it warm up for like 5 min
ORIGINAL: CobraStangGT16
if its cold you can expect to see a light smoke coming from the exhaust and some water vapor. but if its warm there and your seeing a light smoke and a lot of liquid...id say it is your head gasket
i dont drive my car every day and when i do go drive it there is always some water in the pipes from moistier in the air when i get back home the water is gone like said befor check you oil if it looks like choclate milk or some white in the oil then that is bad but if not just check most likly just water in the pipes.
94mustang2003
04-01-2004 12:41 AM
