spray... how much is too much?
02-14-2007, 04:46 PM
how big of a shot can a stock 4.6 hold safely?????
02-14-2007, 04:48 PM
RE: spray... how much is too much?
75-100 safely, 125, should be okay, but no more, anything over is pushing it, n' dont forget a good tune
02-14-2007, 04:49 PM
If it's a stock block, then I wouldn't spray more than 100. I'd actually prob stick with a 75 shot.
02-14-2007, 04:58 PM
Quote:
ORIGINAL: jpmustanggt
+1
02-14-2007, 05:00 PM
so , under normal conditions, decent driver, how much do you think a 100shot would help my times???
02-14-2007, 05:09 PM
125 wet shot with a good tune or 75 dry shot.
02-14-2007, 05:28 PM
you can run 125 all day long. you can run 150 every now and again... 175 will blow the block.
02-14-2007, 05:46 PM
I know a guy that has sprayed a Dry 150+ shot ever 100 times with stock injectors. He took the 150 jet, and actually drilled the orfice out. No telling what shot. 175 maybe. Its nasty. He sprays it on the autoX track. ITs fun to watch. Also run's 11's. Wouldnt reccomend it.
125 should be safe enough as long as your A/F is cool
02-15-2007, 11:57 AM
its an N/X wet kit, i was planning on running 75, just curious just how much it will help
02-15-2007, 12:13 PM
shave about a second off (.75s-1s)ur et with a 100 shot
