D-1SC / P-1SC - Page 2 - MustangForums.com
D-1SC / P-1SC
Old 02-17-2007, 04:10 AM
davidsv8mustang
Default RE: D-1SC / P-1SC
bransdaman78 I would like to know what you mean, since i think you have one if Im not mistaken. Anything will help, Iam just looking for some friendly information.
davidsv8mustang is offline
Old 02-17-2007, 04:26 AM
ZW99GT
ZW99GT's Avatar
ORIGINAL: dsg04gt
Mylongvictor is shooting for 500 + wheel hp with a P1. Unless your going all out, you won't need a D.
You won't NEED it. But if they say its only a $400 upgrade, then why the hell not. I've seen a couple people already that have threw on a entry level supercharger, got bored, built the motor, and are now looking for a bigger/badder blower. Why not do it right the first time?
ZW99GT is offline
Old 02-17-2007, 04:38 AM
2000GT4.6
ORIGINAL: ZW99GT
ORIGINAL: dsg04gt
I would definatly stick with the P though if you have absolutly no intention of upgradeing the stock shortblock. Not only do you save money, but the P should make slightly more power than the D on a low boost setting (less mass, less blower, less power loss etc)
2000GT4.6 is offline
Old 02-17-2007, 04:41 AM
ZW99GT
ZW99GT's Avatar
ORIGINAL: 2000GT4.6
ORIGINAL: ZW99GT
ORIGINAL: dsg04gt
Hmm, never thought about that. I shouldnt be giving advice about superchargers anyways.
ZW99GT is offline
Old 02-17-2007, 05:15 AM
ASUSMC
My D1 made pretty much exactly the same hp as a P1 with the same mods until about 4800 rpm. That is when the D1 really starts to shine. With a 10lb pulley at 5500 rpm I was makin 13 psi and at 6000 I was makin 14psi and my tuner shut down so he didn't blow my motor. The D1 simply gives you more room to grow into. WHEN not if but WHEN you blow your stock motor the D1 is good for more power. I only got the D1 cause that is what Code had but I would never go back. My car makes a ton of power with only the potential for a **** ton more. In other words the D1 can obviously make more power and if you get a rotating assembly that can spin to 7500 consistantly the D1 is well worth the investment.
Plus the D1 is a lot louder. Makes a lot more noise at idle and sounds like a jet at most RPM's.
ASUSMC is offline
Old 02-17-2007, 10:07 AM
04mineralgreyGT
The D1 isessentially the same as aP1 except for a different, more efficient impeller thus allowing it to produce more power in the higher rpm's. If you look at a P1's impeller the blades are straight, then you look at the D1 and the blades are curved over (look more like fan blades on a turbofan jet engine). It's not a bad upgrade if you plan on a little higher boost capabilities later on.
04mineralgreyGT is offline
Old 02-17-2007, 11:11 AM
JJ03MustangGT
JJ03MustangGT's Avatar
or any gas turbine engine___turbo jet____turbo prop....The D1 in my opinion is the better choice. eventually you will get tired of 350-400 hp and ull want more. save yourself the time and hearteache, get the D1. IMO i wouldnt get either if it were my money. id look at paxton or vortech. Id check out paxtons Novi1000 or 2000 and Vortechs V2-SQ. these blower make great numbers. And from what ive heard from a few shops the prochargers have oil leaking issues, and arent the quality of a Vortech or Paxton. but i could be wrong this is just hearsay from a few reputable shops.
ORIGINAL: 04mineralgreyGT
JJ03MustangGT is offline
Old 02-17-2007, 11:55 AM
contentsunderpressur
Go with the D-1. Just because it's much more efficient. With a 3.20 pulley it'll make 18 lbs of boost. If you get the p-1 and decide to build your motor and upgrade afterward it'll cost you 1000 dollars for the upgrade.
contentsunderpressur is offline
Old 02-17-2007, 04:19 PM
bransdaman78
I ♥ Acer
Ok since you asked nicely - the easiest way to put it is that the D-1 is a little bit better than a vortech T trim in regaurds to boost and power output, the D1 will build boost more quickly due to a higher step ratio - also the D -1 sounds sick.. however its not self contained (i think they make both though) the P1 - is equivilant to the v2 vortech, however its louder all the way through and makes a few more ponies in general - but nothing of significance, the difference bewteen the two is basically the same as v2 vs. T trim
also the spec sheet is like all other internet advertising... it falls short of reality, like all of those 900 TT cobras everybody likes to post, however prochargers 1/4 times are pretty dead on, and vortechs listed numbers are very underated... the fastest GT that i have seen (verified) is a pi 96, stock motor v2 sq,10lbs of boost full suspension and slicks, about 395 or so whp, and 420 or so wtq... runing 11.4, give or take a few... pretty impressive.
bransdaman78 is offline
Old 02-17-2007, 04:50 PM
davidsv8mustang
Hey thanks for all your help guys, I'll have to do a little more research now for the next couple months to decide what ill go with. I'll have to look into the D-1SC self contained issue, because thats what really drew me to procharger in the first place. I have heard that they have leaking issues, but i heard the fix is to put the extra gasket (I guess comes with it) on and tightin it up. The D-1SC maybe a very reasonable upgrade that I may go with it if, and only if i can get it self-contained. Thanks again guys.
Sean97
11-21-2006 02:01 AM
6charger8
10-06-2006 12:43 PM
beezy
10-03-2006 11:58 AM
blacllkllsi
08-29-2006 08:13 AM
neogenic83
10-17-2004 02:20 PM
Featured Sponsors
