HELP WITH INTAKE MANIFOLD ASAP PLZ!!!
hey guys im in the process of replacing my all-plastic intake manifold with the new one w/aluminum crossover. I ran into a probleam with the gaskets. The new intake came with those rubber gaskets molded into it (the old plastic one didnt have them), however, there is another big gasket between the manifold and the heads which has a rubber gasket for the old manifold. Now the rubber gastet on the big plastic one is on top and bottom of it, so im not sure as whether to remove all of the rubber material from it or what. Any input is appreciated
Dave
Dave
RE: HELP WITH INTAKE MANIFOLD ASAP PLZ!!!
No clue, when I changed my intake manifold it came with seperate gaskets like stock, but they sucked, and I blew'em out, so I just repalced my gaskets with original ford gaskets...
so what ur saying, czwalga00gt, is that i should throw away the whole black plastic gasket and just use the molded rubber ones that came with the new manifold??
Is the gasket that is between the one on the new intake and the heads an old gasket, or is it new? If it is old, I would say take it out, and just use the one that is with the new intake. When I replaced mine, it didn't have one molded to it, so I just used a replacement gasket.
If your talking about the dorman style intakes,,uses (orange)o-rings only around the intake ports and has its own gasket for the crossover....factory uses the long black plastic gaskets...use the o-rings only....if this is what you have....
yea the plastic gasket is an old one...probly the original one. All right i guess im gonna just use the molded ones and hope for the best....fingers crossed. Cause i really dont wanna see a nasty leak and have to do it all over again. Thanks guys
ORIGINAL: Davojan59
Yes.
