Learn to Build a Motor
RE: Learn to Build a Motor
ORIGINAL: 2000GT4.6
If you have never done it before and have no help from people that have you would be INSANE to just attempt to read a book and then do it yourself.
Personally, I'd look into taking a basic Engine Repair/Overhaul course, since they cover a lot of ground, and put it right in your face, so you can learn by experience; the best tool ever..
Or you can just jump right, invest some hard earned money, all to destroy it when you try priming the engine oil..
JT
i am rebuilding my engine as we speak, this is my first rebuild but as long as you know when to stop and ask someone, when you dont know what you are doing then you should be fine, I have a shop right down the street that builds custom motors and im in there everyday asking them a question. It's really not that hard, just check clearances, buy a feeler gauge set,and use plastigauge. If you are putting in a new rotating assembly then you will need to buy all new bolts, and bearings and make sure it is balanced and you might want to get the block honed/bored while youre in there. But there is a lot of technical stuff to learn, like rotating the rings 30 deg., torque stages and whatnot. but just read and ask questions and you should be fine.
If this is your first build take a course,no ifs ands or buts about it! Take it from me I have been a machinest for the past seven years and i can not tell you how many parts and complete engines i have had to fix because someone had read "every manual and topic" on the process. The best manuals will only show you so much, but it doesnt show you 1/2 the stuff you need to know. the manuals assume that you have had some experance in the past with engine rebuilding. They do not tell you the stuff that is common senseto someone with experance. Just my .02
Thanks for the advice guys, I'll look into seeing what classes are around that I can take, I agree that going into the process without the right information will only lead to disaster.
E.
E.
The only real things that Chilton's doesn't cover is the proper machining process.. Personally, I'd rather have a machine shop do that.. Assembly, sure, they have the torque specs, and some assorted pictures, but not as detailed as someone who has seen it before..
JT
JT
Well obviously Chilton manual doesnt have machining tolerances because thats not something you do in your garage. Thats something for pro machinists to do in a shop with the proper maching equipment. Also check into a Hayne's manual too
Start by buying yourself the proper tools. Engines are all about close tolerances. Look around garage sales for micrometers, telescoping gages, dial bore gages and dial indicators. In Micrometers, you will need a 3-4", 2-3", 1-2" and 0-1". Typically, creating a long-lasting engine is all about clearances and tolerances. Find a good machine shop and CHECK their work, make sure parts are re-ground and bored EXACTLY to stock tolerances. I spent time as a GM trainer, the first thing I taught my students in engine class, was precision measurement, I spent 3 weeks of the course on it. I have an advantage, my Dad had a precision machining business, I started learning to measure at age twelve. To my knowledge, I haven't had an engine blow that I rebuilt, it just takes care and patience, and of course, techniques from the masters. I've sent many an engine back that WASN'T TO MY SPECIFICATIONS OF TOLERANCE after machining. That, and quality parts will do the deal. Read, Read, Read!
John
John
LivingInThePast
09-16-2015 12:20 PM
jaiidutch
09-14-2015 10:29 AM
