Learn to Build a Motor
Let me start by saying I am pretty technical when it comes to cars. Suspension, Brakes, installing my blower, electrical work, etc.
The one thing I have not learned to do and would like to, is how to work on my engine, I would like to buy forged parts and install them. Any suggestions on reading material such as ford manuals or other technical manuals, how-to's or other training to do this. I learn quickly and have lots of time on my hands so I would be taking it slow and learning as I go.
E.
E.
RE: Learn to Build a Motor
Look into a course. Maybe there is a place around you that offers an engine building course. If not, read every book you can find on it, the more the better. That way you get a lot of repeat information that will stick, and some may have better points than others about certain topics. Just my $0.02.
My advice is readin the Sean Hyland manual. but the best advice i can give is to get out there,and just do it. keep a manual handy but the only way i really learn is to just do it. now really complicated stuff tthat involves certain tools i would let someone teach you.
I picked up the Sean Hyland book and am going through it now, so far its informative but a bit over my head as I don't know alot of the basics and terminology, any other 4.6 Modular motor books you guys can recommend?
E.
E.
it's not that great at telling how to build a motor from the ground. it's morely of how to increase the performance and what to pick. and the tools and terminology they use is quite confusing at some points, especially about putting in cams..
I haven't looked but I'm sure there are a few good "How To Rebuild a 4.6" out there. Even the Ford Factory Shop Manuals are pretty good.The problem is that most of them assume that you already have a basic knowledge of building a motor and also assume that you have, and know how to use specific tools, like a Dial bore gauge, Micrometers--both inside and outside, telescoping gauge, dial indicator and set up, things like that. Its really not rocket science but it helps to have this stuff because even something very simple could ruin a rebuild if not done correctly. Good luck.
ORIGINAL: Sap
E.
E.
If I was you, I would buy a high mileage piece of crap 4.6 thats off a wrecked car from a junkyard for as cheap as you can get, pull it apart, and put it back together again before attempting to work on your own engine. Why risk thousands of dollars on an engine you want at your first try of a engine rebuild, when you can find a junker for 100 bucks, and if you put it back together wrong and if youblow it up, it doesnt matter?
