What will I need to complete? - MustangForums.com
Old 02-17-2007, 06:37 PM
tron2003
Default What will I need to complete?
I'm going to be purchasing this short block w/PI heads(28k miles) for my 96 GTNon-PIthat has a 108k miles. I was wondering what parts I would need to purchased and which parts could be snagged from my 96 to complete the engine. Picture below, Thanks in advance.
[IMG]local://upfiles/27019/C158D927AD9042648A2016AD5666DCD9.jpg[/IMG]
tron2003 is offline
Old 02-17-2007, 06:50 PM
97targa
Default RE: What will I need to complete?
You'll need new valve covers(make sure Romeo 11 bolt)or windsor 13/14 bolt) You can use your front timing cover with your accesories and coil packs so that you can retain the same engine harness! Coil packs are good for power levels up to 500hp, they just don't look as clean as Coil on plugs(which are overpriced) You'll want to get a new waterpump to match which ver timing cover you use. Obviously the aluminum crossover intake and heater coolant tubes. That should just about do it! Everything else is swap over
97targa is offline
Old 02-17-2007, 07:47 PM
Cornbread01
i bleave you will need or want the pi manifold i dont see it in the pic correct me if im wrong
Cornbread01 is offline
Old 02-17-2007, 08:44 PM
badboystangGT
make sure you get the correct fly wheel with the correct clutch i'm having that problem right now looks like yours is a 6 bolt crank and your non pi should fit it
badboystangGT is offline
jwog666
01-07-2018 08:16 AM
Lethaldosage423
10-19-2015 01:12 AM
b8checker
10-08-2015 01:55 PM
b8checker
09-30-2015 08:11 AM
mrtrodonet
09-29-2015 12:13 PM
Quick Reply: What will I need to complete?
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
