No traction!!!
RE: No traction!!!
Well, you already know that you need to get new or differenttires so I am not going to bring it up a whole lot... Best bet is gettinga set of nicelower control arms with poly bushings. Helps hook the rear end upa bunch. It helped mineout significantly and I have some cheap tires as well. I amnot going to make that same mistake again. Tires are the single most important suspension component... You should do the same...
09-08-2015 11:50 AM
