Cams in vid up, TT non pi moves on.
RE: Cams in vid up, TT non pi moves on.
It wasnt really hard just tedious, as you can see in the second pic to make room for a clear shot with the dial indicator you can notice how we had to move the power steering/brake lines, and un clip the fuse box and lay it forward out of the way, remove the battery among other stuff. What sux is taking measurements then pulling the cam gear off grinding the key and putting it back on checking it again untill you get it right then you have to make the other side the same and it is just tedious and take a while. Adjustable cam gears would make it go faster but I just dont like the designs and plus if you take your time and be patient there is no need to spend the extra cash for them, unless you dont have bolt on cam gears.
