MM Caster Camber Plates
RE: MM Caster Camber Plates
You'll do fine everything should line right up, drill out the rivet take out the bolts yadda yadda reinstall new plates and get alignment...are you doing any other suspension stuff or no? Dan-
make sure you get the bracket on the bottom of the strut tower on the correct side. i assumed that they were the same for some reason...didn't realize it until i got to the passenger side. locating the 4th hole can be a little tricky, just be sure to use a starter punch so the drill bit doesn't wander. also i would recommend that you primer and paint the inside of the hole to prevent rust.
