Grill Delete Question
I just got my chin spoiler and grill delete from Blue Oval Industry. Very nice quality pieces, however the grill delete didn't come with the screws needed to mount the pony. I read somewhere that there supposed to be security screws. Anyone know where I can get the screws I need? They don't have to be security screws do they?
RE: Grill Delete Question
I used self tapping metal srews on my chin spoiler. They have wide heads on them (plusI put thin washers on as well)and they hold it on very well.
Jack up the front, get a bud to hold it in place and screw in the bolts and you're all set.
NOTE: if you want it to line up flush all the way around you need a hair dryer orheat gun and a bit of patience and it will look great.
I did mine that way.
Thanks guys, I'm referring to the two screws that are needed to mount the running horse. You say I should reuse the stock hardware? So there's two screws there already, I just need to use them to mount the horse? Thanks again I've only had my stang about 5 months.
While on this very subject...I was getting ready to order mine,,and noticed a 2 piece delete kit or a 3 piece kit.....which one should I get ?Is the third piece nesseary?or just another cosmetic piece that adds to the look?
i bought a 3pc from blue oval
the back pice that holds the pony only needs two screws while the stock one takes 4, so i reused the two screws i had leftover to hold the pony to the back piece. also i didnt screw the botom pice to the botomof the bumper, i only screwed it in at the top on both sides. hope that helps
